02-13-2017 23:40
02-13-2017 23:40
My question is pretty much in the title.
Can the Fitbit Alta track running cadence... and is it able to send it to strava (when synced).
It would be great if you could track running cadence live (eg. on the display) but I'd settle for it syncing the average cadence after a run.
Just wondering if I should purchase the Alta for this sole purpose...
Best Answer02-14-2017 11:10 - edited 02-14-2017 11:12
@todef96, Welcome to the Forums! You will not be able to see this information on the display of the Alta. However we have other trackers, like the Blaze and Surge that will give you very detailed information like the running cadence and much more! You can sync a lot from your Fitbit account to Strava, check it out in this post. I would also recommend for you to try our MobileRun feature and the best is that you can try without having the tracker also.
I hope this helps, let me know what you think! ![]()
