06-06-2019 19:36
06-06-2019 19:36
Charge2 not syncing meals/water
Best Answer06-06-2019 20:44
06-06-2019 20:44
We are going to need a little more information @TinaLeigh
Are you entering your meals and water through the Charge 2 on your wrist, as you state?
Or do you enter meals and water through the Fitbit app on some unknown device?
You might also be using the web browser?
Best Answer06-07-2019 05:18
06-07-2019 05:18
Best Answer06-07-2019 06:11 - edited 06-07-2019 06:13
So your question is not about entering food or your Charge 2 but about MFP and Fitbit.
https://myfitnesspal.desk.com/customer/en/portal/articles/2976520-fitbit-sync-issues
Best Answer06-07-2019 17:07
06-07-2019 17:07
Best Answer06-07-2019 19:46 - edited 06-07-2019 19:47
The first post simply said Charge 2 not sync food or water with no mention of what the food and water is suppose to sync to/with.
Saying that food and water is not synced by the Charge 2 implys that water and food gets entered into the Charge 2. In reality both food and water gets entered directly into the Fitbit account through the web or app.
As for the Charge 2, no nobody ever said that it will sync to MFP and it is not suppose to sync with MFP. All Fitbit devices, including Charge 2 will only sync to your Fitbit account.
MFP has set a link up to Fitbit, MFP is responsable for maintaining this link between the Fitbit account and the MFP account.
It is not the Charge 2 or Fitbit that failed but the link that MFP setup that failed.
I posted a link to the MFP site with an update on this from MFP.. Yes as MyFitnesdPal said on Monday they where made aware of a problem between MFP and got right on it. At some point they also reached out to Fitbit for help. They are making progress and a good number of users have had the link up restored.
Most people use Fitbit to record their activity and enter all their food into MFP, not Fitbit.
To sum up. Follow the link above to see what MFP says. This is a problem that needs to be fixed by MFP. At best Fitbit can give some guidance and help figure out what the issue is. But at the end of the day the problem is in the hands of MFP and they are working on it..
Best Answer06-08-2019 11:35
06-08-2019 11:35
Best Answer06-08-2019 12:32
06-08-2019 12:32
MFP and Fitbit where syncing last Sunday. Then Monday something happened. In what way is I passing the buck @TinaLeigh.
Fitbit provided the the interface needed for third parties to access your data, in computer jargon the API. The third party then writes the code to use this API.
Every third party app that access your data uses the same API. If it was For its fault then every app that has a connection to Fitbit would be down.
Strava works. Walgreen's works, Achievement works, my Google spreadsheet is even able to access my data.
The problem is not on fitbit's side, this can be easily confirmed since we know that every other app is accessing their users Fitbit data.
