04-09-2020 12:13
04-09-2020 12:13
I have weight watchers synced with my Fitbit but it will not sync steps. Steps remain zero.on WW. I have uninstalled both Fitbit and weight watchers but it still.does not track steps. Help!
 Best Answer04-09-2020 13:06
                              04-09-2020 13:06
Welcome to the forums!
I'm not sure what you are un-installing and re-installing. If it the apps that wont solve the problem
Also have you set it up?
You can disconnect it the same way above and see it it helps as well
If it doesn't help then you need to get with WW. Fitbit allows it but the connection comes from WW and something could be wrong there
Wendy | CA | Moto G6 Android
                              04-09-2020 13:06
 Best Answer04-09-2020 21:59
                              04-09-2020 21:59
Hello @L2S according to weight watchers your Fit points will sync to weight watchers.
I don't think weight watchers takes the steps from Fitbit, what syncs is up to weight watchers.
