Hi, is there a chance to use Fitbit Charge 6 with SportsTracker app? It even shows connected in the settings but does not show HR or anything. Thanks.
Best AnswerHello @TheLastNatural and welcome to the Community. If this Support page is from the right Sports Tracker app, then the answer is no. This is the Android page. The iOS page also says no.
Laurie | Maryland
Best Answer@TheLastNatural if you are trying to broadcast HR to SportsTracker then it may or may not work. Fitbit implemented it non-standard way and only some receivers can read HR.
Best Answer@TheLastNatural I gave it a go and it did connect and show HR in the app. You need to make sure that Charge 6 will ask you whether you want to connect it to your phone to broadcast. Otherwise, initial connection is there but it won't send any data to the app. You may want to unpair Charge 6 in BT settings and let it pair again when pairing HR sensor. It took me several attempts to do it so I'd say it's easier just to get proper HR sensor that just works 🤷
