05-06-2015
15:58
11:26
SilviaFitbit
05-06-2015
15:58
11:26
SilviaFitbit
Hello all - to keep it to the point...
Current Setup:
What I want to do:
How I do it to produce the issue:
Question I need answered:
A Thought: Shouldn't the sync from MapMyFitness/Ride inform FitBit of this activity and auto-correct?
Thanks in advance!
Gregory
Moderator edit: format
Best Answer05-08-2015 11:36
05-08-2015 11:36
@gwwaus It's great to have you here! Thanks for the details that you've posted. That's correct when you're using your Charge HR and log cycling or biking to your activity log, it won't delete the steps done during that period of time. However, when you log it; you're going to improve the amount of calories that you get.
Also, when MapMyFitness data syncs to Fitbit the data will be override.
Hope this helps ![]()
07-02-2015 16:37
07-02-2015 16:37
Best Answer10-09-2015 08:17
10-09-2015 08:17
Hello everyone! The activities from MyFitnessPal are synced to Fitbit as manually logged activities. Tracked information by Fitbit is synced over to MyFitnessPal, this will include all the data tracked. Also, the Fitbit steps and data con be viewed in the "check-in" section of MFP.
It is also possible to check MFP help site to get extra help!
Hope this helps! ![]()
