05-19-2015 17:49
05-19-2015 17:49
05-20-2015
10:07
14:33
MarlenS
05-20-2015
10:07
14:33
MarlenS
It's nice to see new faces around @Jenbertram! What I recommend is to unlink and relink both accounts. This should allow you to sync your data without a problem. Please follow the steps listed below:
1. Sign into your Fitbit dashboard.
2. Click the gear icon in the upper right corner and select "Settings" from the drop-down menu.
3. On the left side of your screen click "Applications."
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts by going to MFP.
After relinking, you can verify that your accounts are syncing by using one of the following data points:
1. On Fitbit you can check for your meal summary and logged activities from MFP.
2. On MyFitnessPal, go to "My Home," then "Check-In." You should see your weight, Fitbit Steps, and Fitbit Sleep Minutes.
Let me know if this helped you out.
05-20-2015
10:07
14:33
MarlenS
05-20-2015
10:07
14:33
MarlenS
02-25-2016 10:23
02-25-2016 10:23
Thank you, this fixed my problem!
02-27-2016 03:25
02-27-2016 03:25
Welcome to the Fitbit Community @caymansunshine! I'm very happy to hear this troubleshoot helped you get back on track. It's awesome that you are are linking Fitbit with MFP, I'm sure this will be of great help and motivation for you.
Any other questions, let me know.
02-27-2016 12:37
02-27-2016 12:37
My new Blaze is wonderful. However it is not syncing with My Fitness Pal food database. Maybe an update is necessary. Does anyone else have this problem?
02-27-2016 12:42
02-27-2016 12:42
Syncing with MFP is nothing t do with he Blaze but is handled by the Fitbit website in the background so any problem in this area is pretty much guaranteed to be nothing to do with your specific device.
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
02-27-2016 12:43 - edited 02-27-2016 12:50
No fitbit tracker suncs with my fitness pal, it is your Fitbit account that connects up.
I've moved uour post to the third party app forum.
@SunsetRunner please see the solved post above, this should fix it.
03-05-2016 18:37
03-05-2016 18:37
I tried this process on my iphone 6 and it did not solve the problem. It was working fine until 2 days ago. My calories crossover to the fitbit app but my steps dont sync to Myfitnesspal.
05-03-2016 15:18
05-03-2016 15:18
Hi there,
I tried the steps below and after multiple attmeps, I get the same message..."this account already has an account synced, you can only have one account at a time." that is coming form MFP. ...
Any idea on what to do to get this back on track?
06-29-2016 06:42
06-29-2016 06:42
Why isnt my fitbit syncing my exercise with mfp? It was working until today and now it only syncs my steps.
06-29-2016 07:54
06-29-2016 07:54
@sudersuder Exercises will only show up in MFP if it was logged through MFP. Here's how the integration works:
MyFitnessPal → Fitbit
Activities |
Food |
Fitbit → MyFitnessPal
Steps |
Weight |
Hope this helps. 🙂
07-21-2016 11:16
07-21-2016 11:16
My Fitbit app is showing the calories from Myfitnesspal app but myfitnesspal app doesn't register my fitbit steps. It shows my daily goal on the right side but on the left side of that line it has 0 fitbit tracer steps. Do you hvae any advice on how to get it to show my steps?
08-06-2016 19:19
08-06-2016 19:19
mine is doing the same thing ever get it fixed? My cals show up my food, but on MFP my steps aren't showing or my adjusted calories. I'm lost and frustrated it was working just fine until the other day!
08-06-2016 20:19
08-06-2016 20:19
08-06-2016 21:01
08-06-2016 21:01
08-09-2016 18:22
08-09-2016 18:22
@AATTO5 @Emily618 Welcome to the Community! Over the last few days, MFP have had issues with their website. You may want to check the latest news that they posted on their website here.
@zachdean Hey there! Thanks for sharing your experience with us !
08-30-2016 05:28
08-30-2016 05:28
I'm having trouble re-linking My Fitness Pal and Fitbit. Can you please update your solution?
08-30-2016 18:09
08-30-2016 18:09
@Loangal Welcome to the Community! The best troubleshoot to do in this type of cases is to unlink and relink both accounts by doing the procedure posted above. Also, what kind of error are you getting? Can you provide me with a screenshot?
Hope this helps.
09-11-2016 17:08
09-11-2016 17:08
I tried this three times, and MFP is still not reading my steps. MFP reads into my fitbit dashboard, but not vice versa. Any tips?
09-13-2016 16:41
09-13-2016 16:41
@jdurbin5 Welcome to the Community! Thanks for the troubleshoot that you've done. Please make sure that you're seeing the steps data in the check-in section of MyFitnessPal.
Addittionally, this is what gonna sync between Fitbit and MFP check What's gonna sync between Fitbit and MFP?.
Hope this helps.
