07-03-2014 19:07
07-03-2014 19:07
Hi All,
I've got the 3 and use them together for different functions.
- MFP for food and water
- MMF for my walks so far, but I choose this one because I'm planning to be running again
- And fitbit for everything else.
I have a working out routine wich consist of walking home while I use MMF once arrived there I finish workout on MMF and climb stairs for a while which is recorded on fitbit. When I look at my fibt bit calory burned, MFP sync via MMF my walk but I don't have the extra calory burned on the time I climbed the stairs. I hope I'm clear.
Just to make sure here is an exemple. I walk from 8 to 9 and climb from 9 to 9:15 when I see the calory burn chart I see my extra calory burn from 8 to 9 but nothing after.
So what should I do?
Cheers
Marie
07-04-2014 13:00
07-04-2014 13:00
I am not sure that I completely understand, but I will offer this advice. Do not connect MFP and MMF directly to each other. This may cause inaccurate data syncs. Connect Fitbit to MFP and to MMF, but not the other 2 to each other.
