Is there a solution to sync the charge with Runkeeper ?
There is some Fitbit "app" on the apps site but when selected it's not available (anymore)
Or is there something like a workaround to get the Hart rate from the Fitbit to Runkeeper (or strava)?
Best AnswerI would look at the runkeeper info post
When it comes to strava you must use GPS and sync the tracker before turning the tracking function off to have HR synced.
I dont know if the HR will sync to Runkeeper but the post i pointed to woll tell you.
