10-31-2018 14:39
10-31-2018 14:39
Says another my fitness pal account is connected, how do I find it or delete it to connect the one I want
11-01-2018 05:11
11-01-2018 05:11
@Dannybegley Welcome! Thanks for being part of our Community! I will gladly help you with your inquiry. You can revoke the access to your Fitbit app on the app settings area (you will need to use a web browser). Once you revoke the old MyFitnessPal account you can link your new MFP one.
Let me know how it goes!
11-01-2018 05:23
11-01-2018 05:23
Best Answer11-06-2018 10:39
11-06-2018 10:39
If MFP is not connected to the account your logged into, you will want to log into your MFP account then revoke access to fitbit.
It might take a few minutes for Fitbit to realize.
Then through MFP connect your Fitbit account, making sure you are logged into the correct Fitbit account.
11-08-2018 08:52
11-08-2018 08:52
Hello @Rich_Laue and @Dannybegley.
In this case trying what @Rich_Laue mentioned is the best way to go about it.
Additionally, could you share the screenshot of what you see when you try to revoke access from your Fitbit account?
Let me know if you have any further questions.
Best Answer11-15-2018 08:20
11-15-2018 08:20
Best Answer11-15-2018 09:33
11-15-2018 09:33
I think I would contact mfp and ask them.
11-16-2018 09:55
11-16-2018 09:55
Hello @Dannybegley and @Rich_Laue.
I agree with what @Rich_Laue said. Please do try to get in touch with them directly so that they can see exactly what is going on.
