I use my Charge 6 for biking, spinning, running on treadmill, weight training. I want to be able to sync all activities to Strava. However, the only activities that will sync to Strava are those with GPS data. Spinning and weight lifting do not have GPS data built in to the activities so none of my spinning or weight workouts get uploaded to Strava. Is there any way to change this so that all exercise activities get uploaded to Strava?
Best Answer@TomRH1955 not an easy one. You'd need to extract incomplete TCX file but that would give you only HR and then you'd need to upload it manually. Fitbit decided not to support Strava integration for non-GPS activities long ago and unlikely it's going to change now. Alternative is using watches which have such support.
