06-22-2015
21:34
08:41
AngelaMa
06-22-2015
21:34
08:41
AngelaMa
So, I got my fit bit charged it put it on and worked out for a bit. Got home and pluged in the dongle went to myfitnesspal and I have no idea what happened next but now it says I have an acct. I can get to a dash board, not sure if its real and nothing seems to happen. On fitnesspal if I click on exercise it shows calories burned from the fit bit if I click on the Fitbit calorie adjustment but not sure if it's real. I can't seem to find a place to setup my fitbit anywhere, things like getting out of the 24 hour clock. Any help because I'm thinking I'm lost big time.
Thanks for any help there might be out there.
Mike
Best Answer06-23-2015 04:46
06-23-2015 04:46
One would need to start with downloading Fitbit Connect, and it can then be used to view
various items and make various settings. There should be an instruction booklet to follow.
Wendy will likely provide a welcome shortly.
Best Answer06-23-2015 07:07
06-23-2015 07:07
How do I find a post that I put up on June 22nd?
Best Answer06-23-2015 07:16
06-23-2015 07:16
Hello and welcome to the forums @hmichaela
I moved your post over here where your first one is. To find something you posted, just click on your name and it shows all your posts. Click here to see what I mean.
10-09-2015 09:02
10-09-2015 09:02
@hmichaela Hope you are doing well! I will like to know if you are still experiencing the same issues with the calorie adjustment on MFP? You can always check MFP help site too. Also, to setup the Fitbit tracker you can go to this link here.
Let me know any updates you may have.
