Dashboard calories from myfitnesspal not accurate
I have myfitnesspal and fitbit linked. The last two days my calories from myfitnesspal to the fitbit have not been correct. Anytime I would change a meal in myfitnesspal it is creating a new log in fitbit. So I have double or triple the calories from some meals. I've tried forcing a sync and completely deleting a meal then re-entering it. Both have not worked. What should I do?
4 REPLIES 4
It's great to see that you've visited the Fitbit Community @Cbaker. In this case, I would recommend revoking the access between your Fitbit and MyFitnessPal accounts and link them once again. Hope this helps.
Catch you later. Robot Very Happy
I am having the same issue! So do the Fitbit group read. These issues
I'm also having this issue and revoking the access and setting it back up didn't do anything to help.
Thanks for joining us @Retiredgirl @NJ84. If you keep experiencing the same issue after trying the above workaround, please contact MyFitnessPal customer support through this link.
 Keep up the super stepping. Robot Very Happy
