05-18-2019
10:48
05:56
LanuzaFitbit
05-18-2019
10:48
05:56
LanuzaFitbit
Hi,
i have made a web app that upload Fitbit NON GPS activities to Strava.
If you want to use go to https://www.fittostrava.com
At this moment it's a first release, so tell me if it works fine.
Thank you.
Marco
05-19-2019 05:55
05-19-2019 05:55
Hello @shppotta.
Thank you for taking the time to develop it and posting about it in here.
Hopefully other users will definitely find it useful and help the app become very useful.
If you have the time, be sure to visit one of our Discussion boards. Lots of different topics to talk about with other users, maybe something there will pique your interest.
Let me know if there are any further questions.
08-21-2019 15:25
08-21-2019 15:25
Hi Marco. Would it be possible for you to share the source code for you web app. As much as I want to try your app I am very hesitant to just authorized an unknown application to access my data. You must surely understand 🙂 . If you could make your application open source that would be a great win for the community!
Thanks in advance!
Akos
08-24-2019 06:55
08-24-2019 06:55
Hi there. I tried your website and it worked perfectly for me. Thank you for your app! I was desperately looking for something like this!
10-21-2019 03:56
10-21-2019 03:56
01-19-2020 07:04
01-19-2020 07:04
Great webapp, congratulations. Works great.
The one issue I have is as I tested I logged out and it seems to logout from fitbit only. So I went to strava em revoked access, so the web app does not have access to it, but the webapp still thinks strava is connected and there is no way to reconnect it.
01-21-2020 08:17
01-21-2020 08:17
Will this setup show heart rate information if an activity is started via phone app? Activity via phone app will give GPS, but no HR data, activity via non GPS tracker will give HR data. I am looking for a way to start a run on the phone and get the HR data for that activity. I can only get this combo when starting run from Ionic. I work with a few Alta users that have to choose HR or GPS readouts.
06-14-2020 14:32
06-14-2020 14:32
The app works great for non-GPS activities , so far everything is correct. Thanks a lot and keep up the great effort. Definitely what I have been looking for
07-05-2020 23:32
07-05-2020 23:32
Is there a way of adding a distance does anyone know? this does not export
08-13-2020 10:59
08-13-2020 10:59
Great job with this app and exactly what I've been seeking for my Fitbit Ionic. I do indoor recovery rides after my outdoor rides and want to sync that data as it also affects Strava Fitness/Freshness rating.
Found the best way to do this is start the indoor ride as a workout then it can be changed to a ride in the Fitbit app. Then sync thru your app and BAM! This method is easier than disabling GPS and logging as a ride and then don't have to forget about re-enabling GPS etc. Thanks again!
09-23-2020 02:31 - edited 09-23-2020 04:26
Is there a problem just now with this, it's been working great for me but the last 2 days when I export my activities to strava it says it has uploaded but when I go to strava my activities don't appear?
09-23-2020 02:44
09-23-2020 02:44
I have the same issue
09-25-2020 00:09
09-25-2020 00:09
Hi,
the problem was solved.
Have a good sport day 🙂
Marco
09-26-2020 00:19
09-26-2020 00:19
Hi
The site has been working well for me for the past month, but since yesterday my Fitbit activities no longer show on Fittostrava when I sync it with Fitbit.
Thanks
09-26-2020 10:28
09-26-2020 10:28
Same issue - no sync to strava for a non gps based sync.
09-27-2020 08:36
09-27-2020 08:36
I wanted to use your application today for the first time. However, somehow when I connect my fitbit account my activities don't show, so I am unable to convert.
09-29-2020 07:30
09-29-2020 07:30
The app syncs the activities only those tracked automatically or those tracked by the device.
So, the activities tracked manually are not synchronized.
10-02-2020 09:49
10-02-2020 09:49
Tried using this - authorized access to fitbit/strava, activities show on fitbit, when selecting upload to strava, it confirms uploaded, though nothing appears on strava
10-05-2020 02:29 - edited 10-05-2020 14:17
Hi Marco, I have the same issue after it was resolved the other day. It used to work fine, but since a day or two uploading to strava seems broken again.
