07-27-2014
19:04
12:16
AngelaMa
07-27-2014
19:04
12:16
AngelaMa
My estimated calories for a sedentary lifestyle on myfitness pal is 1600/day. My fitbit estimates my calories burned even after walking 3 to 4 miles and several flights of stairs as around 1500 calories. Who is right here?
Best Answer07-28-2014 05:28
07-28-2014 05:28
@donamy wrote:My estimated calories for a sedentary lifestyle on myfitness pal is 1600/day. My fitbit estimates my calories burned even after walking 3 to 4 miles and several flights of stairs as around 1500 calories. Who is right here?
@donamyA couple of things, both MFP and Fitbit use the same BMR calculator as confirmed to me by Fitbit Support a few months ago. Here is the calculator and the result is only 5 calories different for me.
http://www.myfitnesspal.com/tools/bmr-calculator
Also stairs do not generate extra calories because Fitbit cannot detect exertion, it is only the steps and speed, and there is some consensus that going up stairs you will burn more which you need a HRM to record, and going down stairs it is lighter effort and one may even the other out so the tracker could be accurate.
Was your 1500 calories the full 24 hours ?, because calories burned is normally about 75-80% BMR and the remaining 20-25% exercise and genetics. Fitbit includes BMR in all of its activities.
My BMR is 1584 and my average at days end for just under 10,000 steps is 2,400 calories average. The average distance is 2.5 miles/day. Looking at your profile youy should have a similar "end day" calorie burn.
08-08-2014 10:06
08-08-2014 10:06
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
