Difficulty syncing with MyFitnessPal
I'm having difficulty syncing with my fitness pal account. They don't recognize either of my email accounts. Wondering if I should bother. Is fit bit diet the same as my fitness pal?
1 REPLY 1
Thanks for stopping by @Montsclamato! To answer your question, the food plans on each application might be different, however, I do not have a way to find out how MFP calculates or establishes your numbers. If you are having issues with syncing your Fitbit account with MFP, you should unlink and relink both accounts by doing the following:
1. Sign into your Fitbit dashboard.
2. Click the gear icon in the upper right corner and select "Settings" from the drop-down menu.
3. On the left side of your screen click "Applications."
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts by going to http://www.fitbit.com/apps/myfitnesspal.
After relinking, you can verify that your accounts are syncing by using one of the following data points:
1. On Fitbit you can check for your meal summary and logged activities from MFP.
2. On MyFitnessPal, go to "My Home," then "Check-In." You should see your weight, Fitbit Steps, and Fitbit Sleep Minutes.
I hope this gets you back on track! Smiley Happy
Melissa | Community Moderator, Fitbit
How are you fitbitting with your (pet) best friend? Show us!
