01-16-2020
13:04
11:22
SilviaFitbit
01-16-2020
13:04
11:22
SilviaFitbit
Has anyone had any luck trying to sync the Fitbit Charge 3 to Fat Secret? On my app it shows the box is checked however no information ever shows up. I am not sure if I have done something wrong, or if fitbit just doesn't work with Fat Secret? Is there a better calorie counting App that works well with Fitbit?
Thanks
Mary Ellen
@boogerqwn Welcome to the Community. Thanks for the details mentioned.
There are tons of apps that use our Open API to integrate their service with ours. The best way to tell if an app is compatible with Fitbit is to go to the third-party site (or app) and poke around their settings to see if you can connect Fitbit. You can also browse their site for information or contact the app owner and ask if they integrate with Fitbit. Learn more about it by checking this post: Third Party Apps - FAQ
Additionally, you may want to check the third-party apps in this list.
I'll be around if you have any additional questions.
Best AnswerThis question would be better to as Fat Secret or do as search of Fat Secret Fitbit
I found a response on their community board that says yes.
