12-31-2015 12:04
12-31-2015 12:04
Best Answer01-01-2016 07:59
01-01-2016 07:59
Welcome to the Forums @Teddy77. If your MyFitnessPal data isn't syncing to your Fitbit dashboard, I recommend unlinking and relinking both accounts.
1. Sign into your Fitbit dashboard.
2. Click the gear icon in the upper right corner and select "Settings" from the drop-down menu.
3. On the left side of your screen click "Applications."
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts by going to http://www.fitbit.com/apps/myfitnesspal.
After relinking, you can verify that your accounts are syncing by using one of the following data points:
1. On Fitbit you can check for your meal summary and logged activities from MFP.
2. On MyFitnessPal, go to "My Home," then "Check-In." You should see your weight, Fitbit Steps, and Fitbit Sleep Minutes.
Let me know how it goes! ![]()
Best Answer08-24-2016 13:00
08-24-2016 13:00
Hi,
I have a similar issue. Steps, and Sleep are syncing, but exercises are not. I have to manually enter exercises in MFP. How can I fix this?
Best Answer08-25-2016 05:16
08-25-2016 05:16
A warm welcome to the Community @award75. Have you tried the steps provided in the previous post? If you haven't, please try those steps to sync your information from your Fitbit to your MFP account.
See you around! ![]()
