02-24-2018 10:24
02-24-2018 10:24
My Fitbit tracked exercises used to sync with MyFitnessPal so I could get credit for the exercise I do against my calorie total for the day. Now for some reason it only tracks steps taken, not anything else such as the cardio workouts. I have tried everything such as deleting both apps and reinstalling, etc. they show as connected but no exercise info is syncing. Please help.
10-23-2019 11:36
10-23-2019 11:36
Hi there,
not sure this can help and sync everything you want, but... if you still have issues with MyFitness Pal, maybe you could try this solution (Fitbit sync to Endomondo and then Endomondo to MyFitness Pal):
Best Answer10-23-2019 17:25
10-23-2019 17:25
Or a user might want to contact MFP, they are responsible for their connection to fitbit.
11-12-2019 18:57
11-12-2019 18:57
RobertoME,
I just returned to a Fitbit after a year or so with a Gramin. The same calorie issues happened to me whereas it used to always sync from what I remember. I tried your disconnection method off both websites, waited and re-established the apps... and presto! It worked. Thank you so much... just hope it stays working.
Best Answer11-14-2019 07:17 - edited 11-14-2019 07:18
I was desperately hoping that LostEcho's suggestion would solve the problem, but unfortunately exercise doesn't seem to sync to endomondo either, just steps.
I'm now on a quest to find any app it actually syncs to in the hopes that I can sync that data back into myfitnesspal so that I can participate in the challenges again. Or just hope that things change once Google takes over...
Best Answer11-14-2019 22:08
11-14-2019 22:08
If your interested in what Endomondo says that they sync from fitbit. See there help doc.
Please remember that fitbit provided the tools, third party sights like endomondo are in complete control of what they want to take from fitbit.
If your having issues with MFP or Endomondo, the best thing to do is to contact them.
Best Answer12-16-2019 04:59
12-16-2019 04:59
I've had the same issue. I've got a Fitbit Flex2. Every time I completely disconnect and reconnect the apps, it updates my step count in MFP once. But it refuses to update again when my step count increases. The fitbit app works perfectly and MFP has no issues, it's just the communication between the two. I've revoked access and reconnected. I've done everything suggested on all the forums I've read. But unfortunately had no success so far. HELP, please! 🙂
Best Answer12-16-2019 08:23
12-16-2019 08:23
@hayley8072 the transfer of data between Fitbit and MFP is handled by MFP not Fitbit. Your best course of action would be to contact MFP.
Best Answer05-15-2020 14:36
05-15-2020 14:36
Thank you. This fixed the problem immediately for me.
Best Answer05-19-2020 14:38
05-19-2020 14:38
Just to let people know if you’ve spent half an hour looking for this information like me, if you have an iPhone this doesn’t work.
Instead you need to go to account, then under privacy and security click ‘manage data’ you will then be given change to ‘manage 3rd party apps’ and revoke data like suggested above.
However for me this still didn’t fix the syncing problem between mfp and Fitbit.
Best Answer05-20-2020 04:23
05-20-2020 04:23
Best Answer01-08-2021 05:04
01-08-2021 05:04
So basically, after reading this thread, I'm better off keeping mfp and fitbit separate. Sucks, but I honestly don't care about logging steps when I'm murdering in the gym and not getting credit
01-18-2021 16:34
01-18-2021 16:34
It used to work fine for me. I have a lung disease and every bit of walking/exercise I do helps. I'm ticked off. I've gone through all the steps to revoke and then re-add and it doesn't work. 😡
Best Answer02-22-2021 12:04
02-22-2021 12:04
Apologies if this has been posted elsewhere but I have found a (somewhat clunky but effective) workaround using Strava. Essentially you link Strava to both Fitbit and MFP.. This will sync all GPS fitness activity (via Strava) but not other Fitbit cardio, such as spinning. However, by using the rxvellent
third party site (https://www.fittostrava.com) you can manually sync ALL activity (again via Strava to MFP). It annoys me that I have to jump through all these hoops, but it definitely does work. Hope this helps.
07-26-2021 13:02
07-26-2021 13:02
Same problem here. Unlinked the two accounts, and now I can’t relink them…
01-09-2023 22:51
01-09-2023 22:51
This is a 4-year-old post and it still doesn't work right. My steps are always calculated but my workouts never transfer
02-20-2023 13:14
02-20-2023 13:14
Will the "Perpetual run around" automatically sync to both apps. An additional Stress Measurement feature would also be a nice feature for these apps to track. 😉
Best Answer06-02-2023 09:43
06-02-2023 09:43
How do you turn off the adjustment?
Best Answer06-14-2023 18:58
06-14-2023 18:58
So disappointing to see that 4 years later this still isn't working.
06-15-2023 18:17 - edited 06-16-2023 10:01
Yeah this sucks. I used to have to use Edomondo to sync exercises....but NOW that app is waay past defunct. So I use fitbit, unfortunately, it doesn’t track calories right in myfitnesspal. I mean, I can walk to the grocery store and "burn more calories" according to the sync, then if I’m hitting it hard for more than an hour in the gym...because its all based on walking/steps???!! Lame.
p.s I’m sure this more on the “Fitness pal” end...thye each want you to solely use their app…
