Exercise tracked using surge gps does not register on my fitness pal
When I track exercise using my Surge gps (hike or run) the calories I gain/burn does not sync with my fitness pal as it used to do when I was using my flex. For instance, today I have done 17,000 steps - this includes a walk/run of 3.5miles and a walk of 2.5 miles - and Myfitnesspal only adjusts this to 300 calories. When I look on my tracked exercises the calories burned is more like 800. Can I adjust this to sync to the right amount? Thanks
10 REPLIES 10
Thank you for being part of the Community @Jessiepb! This is really easy to fix, the only thing you need to do is unlink and relink your Fitbit and MPF accounts, rest assured that you won't lose your information.
Let me know how this works and good luck Smiley LOL
Fitbit Community ModeratorVivian | Community Moderator, Fitbit
Did this help you? Help others by marking it as a solution! 🙂
hopefully it is fixed by now, but around the time May 5th, MFP had announced there was a problem with syncing and Fitbit.
Hi. I've unlinked and relinked and no steps show in myfitness pal at all. Help still needed!
Thanks
Have you contacted MFP yet, Fitbit allows them to rrad your data, Fitbit does not send it to them.
My Surge is not syncing any of my steps with my Fitness Pal.  Everything was working fine up until a week ago. Also I have been unable to manually sync to update My Fitness Pal. Can someone help me?
Modetaror Edit: Format
Hi @Jazzercise I've moved this thread to the third party app area, this is where people are that know more about mfp than i do.
Thanks for doing that.
Jacqui
Sent from my iPhone
Welcome to our Community @Jessiepb and @Jazzercise! I'd like to know if you're still having issues with syncing your information between Fitbit and MFP. Thanks for your support @Rich_Laue!
Looking forward to your reply!
Hi There,
Thanks for your email regarding my problem. So far I don't have any more
problems and hope it lasts. What I did was re-load my Surge and that solved
the problem. I really didn't want to remove My Fitness Pal or my Surge and
add them again. Hope everything keeps going. It make life easier.
Thanks for asking,
Jacqui/Jazzercise
Hey @Jazzercise! Thanks so much for your update, I'm glad to know that your information is syncing fine now between Fitbit and MFP. I'm pretty sure this won't happen again. When you un-link and re-link your accounts, any data is deleted. So rest assured that once you sync your details, you'll keep your information as it is.
See you around!
