12-04-2016 18:43
12-04-2016 18:43
Yesterday I told fit bit to not sync exercise with MFP and but ONLY EXERCISE and ever since than my food from MFP to FIT stopped syncing. I did revoke access again and redid it. But still not syncing food. Ideas? TIA
Shannon
Best Answer12-05-2016 17:14
12-05-2016 17:14
A warm welcome to the Community @Axzure! Currently, Fitbit will sync just steps and weight to MFP. Instead MyFitnessPal will sync activity, food and weight to Fitbit. I'm not sure what exactly you did about not allowing anything but exercise to sync to Fitbit. Can you provide me with more details?
If after unlinking both apps, your information is still not syncing. Please contact them directly so they can further investigate it.
Hope this helps!
Best Answer12-05-2016 18:26
12-05-2016 18:26
When you link mfp and fit bit it gives you a list of what you want to sync. At first I had everything synced. Then I unconnected them and reconnected them but this time I unchecked exercise and activity but left all the others checked. Which it did stop syncing the activities and exercise yay but it also stoped syncing my food. Which was not what I wanted.does that make more sense?
