11-20-2016 16:25
11-20-2016 16:25
Best Answer11-20-2016 23:58
11-20-2016 23:58
You've not given us much to go on. Best I can offer is fitbit's guide to setting up the link:
Best Answer11-22-2016 17:04
11-22-2016 17:04
Thanks for the information provided @SteveH!
Welcome to the Community @Compatible! What exactly you mean by saying you're having a hard time to sync Fitbit with MFP? As @SteveH mentioned, are you trying to link both accounts? Are they not syncing information between each one?
You may want to check the MyFitnessPal post to learn more about this integration.
Hope this helps.
