I can no longer view any of my Todoist lists on my Sense. The Fitbit app with Fit for Todoist is installed on an Android. If I select Troubleshooting / Run Diagnostics in the Fit for Todoist app settings it gives a 'Token: not found' message.
The developer is Rune Apps, there is no contact or website as far as I can see.
Any ideas anyone? I was using this app quite regularly.
Hi there @gsofit. Welcome to Community Forums.
I recommend you update your OS from the device you are using to sync your Fitbit Sense, as well check if you have the latest update for the Fitbit Firmware. If you have those up to date, some users usually find it useful to unpair and then pair both apps again to refresh the performance, if you already have them paired.
Or if you'd like to contact our Support Team or the third party customer service for more information.
I'll be around.
I'll be around.
Best AnswerThanks for the reply, todoist has long since started working again probably because I did one of the things you suggested, and it does a great job, thank you for looking in.
Hi @gsofit. It's good to see you back in the Community.
I'm glad you got it working again.I also suggest you visit our Health & Wellness board where you can share your experiences, meet people and create new topics.
Have a nice day.
