07-08-2015 06:45
07-08-2015 06:45
So I use Strava to track my cycling events. I have linked my fitbit and strava. I have a fitbit flex. I usually wear my fitbit when I cycle. I have to assume that when the two apps link the active minutes and calories burned end up being doubled. Would that seem accurate?
13:04
06:34
07-09-2015
13:04
06:34
@j_rapp76 It's nice to see you here! The activities that you manually track with Strava will override the data that your Flex has tracked so you shouldn't be getting double information. I would like you to check if the information is going double or it happened just once.
Let me know how it goes.
