12-03-2016 08:15
12-03-2016 08:15
1. I have synced myfitness pal and Fitbit (Charge 2)
2. Fitbit IS oulling My Calories Eaten Data in no problem
ISSUE
1. I track exercise (Walking) (Running) (Weights) By Starting and Stoping the various exercises on my Fitbit - This Data is showinig up in my Activity in my FITBIT App However NONE of the activity Data from Myfit bit is populating in Myfitness pal
To Recap, FITBIT Pulls Calories cosumed data from MFP but MFP WONT pull Calories Burned, Exercise data in... If I manually enter the Exercisse in MFP I get Double enteries showing in Fitbit
HELP!!! This is SUPER ANNOYING!!!!!!!!
Best Answer12-03-2016 08:15
12-03-2016 08:15
PS : I have Disconnected the apps and re-synced-- No Effect
Best Answer12-03-2016 13:47
12-03-2016 13:47
A warm welcome to the Community @Ironclash! Thanks for the troubleshoot that you've done. Fitbit will sync steps and weight to MyFitnessPal. (You can check this data in the check-in section). You don't need to log your activities in both applications because this will override the information you already had. There will be a calorie adjustment made if your calories burned don't match in both apps.
Any activity that you log in MyFitnessPal should show in Fitbit. However, keep in mind that you should log activities where you don't use your tracker or activities that require more than just steps such as tennis or yoga. You can learn more about this integration here.
Hope this helps!
Best Answer07-16-2017 16:14
07-16-2017 16:14
Hi,
I have a same problem.
Yesterday, I burned 34cal in Yoga with fitbit. → 0 adjustment
Today, I burned 294cal in spinning with fitbit and some walking(around 2miles)→ 110 adjustment
Is this correct?
Thank you,
Best Answer07-17-2017 06:10
07-17-2017 06:10
A warm welcome to the Community @mikausa! The calorie adjustment will be made based in the data that you have in both applications. Based in the information that you've mentioned, I believe it's fine.
(I've attached an example of the adjustment that I got) It's showing negative because I got just one more calorie burn in MFP.
Hope this helps!
Best Answer07-19-2017 17:15
07-19-2017 17:15
Thank you very much, @SilviaFitbit
I have been using myfitnesspal to log my exercise and food intake.
I would like to log exact name of exercise which I did on myfitnesspal, so I will disconnect fitbit and myfitnespal.
Thank you very much for your kind explanation.
07-21-2017 06:17
07-21-2017 06:17
I'm glad to hear that you'll continue using MyFitnessPal and Fitbit @mikausa! You can always continue learning about it by checking this third-party post.
Hope I can see you around, you may want to check the Discussions board and find healthy tips or meet new people. 🙂
