09-09-2016 14:41
09-09-2016 14:41
Best Answer09-10-2016 15:32
09-10-2016 15:32
@MJflower1 Welcome to the Community! Fitbit will sync steps, calories burned to MFP. MyFitnesPal will sync food and activities to Fitbit. The steps are going to be viewed in the check-in section. What are you not seeing in your apps?
Some troubleshoot that you can try is unlink and relink both applications. Go to your Dashboard > click on settings > applications > choose MFP and click on "revoke access". As well in the MFP website. (check the screenshot).
Keep me posted.
