07-21-2017 09:03
07-21-2017 09:03
I have a new Fitbit Alta HR that works great...love it...but it's not syncing with myfitnesspal even though I have the apps linked. How do I get it to sync and add the extra calories I'm burning to myfitnesspal? I tried deleting the app and reconnecting it and it still didn't work.
Best Answer07-21-2017 09:49
07-21-2017 09:49
Make sure you go into your "Steps" setting and enable Fitbit as your step tracker
Best Answer07-21-2017 13:34
07-21-2017 13:34
How does that help them sync?
07-21-2017 14:17
07-21-2017 14:17
MFP allows you to use multiple sources for fitness/step tracking (ex: Fitbit, Google Fit, etc).
You have to select one for it to sync the exercise.
Best Answer07-21-2017 17:19
07-21-2017 17:19
