Is it possible to sync my HRV from the Fitbit app to Training peaks? My coach would like to see this metric and I can't seem to get it to automatically sync. HR data is shared if I record a workout on my Fitbit but I would like the Health Metrics to be synced even if I don't record a workout.
Any help appreciated
Best AnswerIf you mean these daily metrics:
then I don't think you can get Fitbit to share it to thirdparty app. Some metrics are only available to Fitbit. I didn't have much luck with pairing Fitbit with TP though (not even workouts).
Yes those are the ones. It looks like a manual job to enter them into TP. I’ve put in a ticket at TP to see what they say but I’m not holding my breath.
Best Answer@JimbobMcnuget some data is not exposed on the Fitbit side so TP won't be able to do much (and let's face it, Fitbit users are probably only a fraction of all TP users 🤷). Most TP users use Garmin so TP prioritize them.
Best Answer@Triletics It’s does look like TP is the problem, Fitbit exposes HRV in its API so it should be easy to get this then write it to TP. I thought I might just write the code myself but TP is fussy with who use as their API so I doubt I’ll get permission.
Oh well it’s not the end of the world. I have to write a note to my coach every day anyway so it’s just another box to fill in. Thanks for the replies.
