01-09-2017 08:18
01-09-2017 08:18
MFP and fitbit app are not syncing anymore. None of my steps from my fitbit are registering on MFP despite fitbit being selected as the source of steps on MFP. It also isn't transferring my workouts over or showing me how many calories I have left. When I looked on the webpages for both of the apps, it says that MFP has access and that they are connected. I tried disconnecting, waiting 15 minutes, and then reconnecting, but that hasn't worked. Any tips you could give me would be great!
01-09-2017 12:25
01-09-2017 12:25
Same here!
@aliwolf wrote:MFP and fitbit app are not syncing anymore. None of my steps from my fitbit are registering on MFP despite fitbit being selected as the source of steps on MFP. It also isn't transferring my workouts over or showing me how many calories I have left. When I looked on the webpages for both of the apps, it says that MFP has access and that they are connected. I tried disconnecting, waiting 15 minutes, and then reconnecting, but that hasn't worked. Any tips you could give me would be great!
Best Answer01-09-2017 22:57
01-09-2017 22:57
I am in the same boat. Following so I know what to do. 🙂 thanks!
Best Answer01-10-2017 03:43
01-10-2017 03:43
Unfortunately I'm in the same boat too. Have been for a couple of months, contacted MFP but they haven't got back to me. Having to manually add calories each day which is a massive pain! Have deleted and reinstated both several times 😞
