02-17-2020
16:02
15:16
SilviaFitbit
02-17-2020
16:02
15:16
SilviaFitbit
I have used Map My Ride for several years, mostly for bike rides. The app and the website both say they are connected to my Fitbit. I went XC skiing and logged it as a hike. At the end, my Fitbit told me how long I had been out, how far I'd gone, etc. But there's no connection to Map My Ride. It doesn't show up. I went to the Map My Ride website and synced the device. Nothing. Will my watch send info to the app or not?
Moderator Edit: Labels
Best Answer02-18-2020 00:09
02-18-2020 00:09
When you did cross country skiing, did you have GPS enabled?
Best Answer02-18-2020 17:18
02-18-2020 17:18
Yes. When I look in the settings it says Connected GPS is on.
Best Answer03-09-2020 18:08
03-09-2020 18:08
Interesting. I've been using MapMyRide for skiing for quite a while. Today I was on the mountain and Fitbit shows no exercise. I would have thought that, since there as are connected, some sort of activity would show up. Your idea of logging it as a jog might work, though the fact that there are few "steps" registered will still probably confuse my Fitbit versa 2.
To bad there is no support for snow/ice sports or for importing data properly from connected apps.
Best Answer03-09-2020 18:49
03-09-2020 18:49
@AlanJOQ connected apps are responsible for their connection with Fitbit, of the third party app decides not to send your data to Fitbit, that is their decision, not fitbits.
