08-02-2018
18:03
05:19
08-02-2018
18:03
05:19
Is there any way to get my exercises and workouts to sync from fitbit to my fitness pal? when I enter my workouts on my fitness pal it will then sync to fitbit. I purchased a fitbit in hopes that the actual workouts recorded in fitbit would sync to my fitness pal and be more accurate and I would not have to enter it on my fitness pal. Is there anyway this can be done? Otherwise, it gets recorded twice in fitbit. Thanks in advance.
Lisa
Best Answer08-03-2018 05:21 - edited 08-03-2018 05:26
Welcome on board @Dolphin228, I'm glad to have a new member around!
Well, you're right, it gets recorded twice in your Fitbit dashboard if you do it that way.
Note that only steps from your Fitbit will sync to your MyFitnessPal account.
As additional information about having Fitbit and MyFitnessPal linked, is that based on your profile settings (which should be the same in both Fitbit and MFP) the system expects you to burn a certain amount of calories per day. If your activity is lower than expected then you will burn less than that.
If the negative adjustment is on then Fitbit will tell MFP that you have been less active and will reduce the calories you can eat. If it is not set on then it won't adjust the calories down in this case. Whatever it is set to, if you are more active than expected then Fitbit will tell MFP and it will raise the calories you can eat.
Said that, MyFitnessPal pulls your calorie burn directly from Fitbit's total daily calorie. We then project forward to the end of the day based on your calorie burn so far. If this full-day number is different than MyFitnessPal’s estimate for your daily calorie burn, an adjustment will be made to your caloric intake goal. This adjustment can either be positive or negative. If the adjustment is positive, this indicates that your calorie burn for the day as reported by Fitbit is greater than MyFitnessPal’s estimate. If the adjustment is negative this indicates that the partner's reported calorie burn is lower than MyFitnessPal’s estimate.
Since the adjustments are made on MyFitnessPal you should activate the negative adjustment in Fitbit by doing the following:
Log in to the full MyFitnessPal site at www.MyFitnessPal.com and click the main "Settings" tab, then "Diary Settings." Check the box for "Enable Negative Adjustments" then click "Save Changes.” If you are typically unable to sync your device until late in the day, you may wish to leave negative adjustments "off." You can learn more about the adjustment here.
If by any chance you're not able to sync your Fitbit steps to MFP, check this post.
I moved your post to the Third-Party Integrations as there are more chances to get app related replies here.
Hope this clarifies your question, let me know if you need further assistance!
