Fitbit and myfitnesspal not syncing together
I use myfitnesspal to track my food and then sync it to my fitbit but I just noticed it hasn't been syncing to each other for the last 3 days... not sure if it's a fitbit issue or a myfitnesspal but if someone could shine some light on the topic. Thanks
6 REPLIES 6
Mine has been doing the same thing since Friday, October 21, 2016. I'm getting calorie updated TO Fitbit FROM MFP, but my step count FROM Fitbit back TO MFP shows up for a short while and then resets back to zero. Four days of this behavior with my new Charge 2. I have reset all the settings, unlinked/relinked the apps via the website, and uninstalled/reinstalled both apps on my iPhone. I get excited for a short while because it suddenly starts working for a short while *after I leave it alone*, but then I go back to add something to MFP, like I just did by adding my dinner, and poof, no steps.
Mine is doing the exact same thing, and has been for the last 3 days as well. I've deleted everything and reconnected and still nothing. Grrrr.....
I'm having this issue as well, but neither steps nor food is syncing in either direction for me. I've tried disconnecting and reconnecting the apps multiple times with no luck. 😞
Same here.. disconnected, uninstalled etc etc.. No change. Hopefully someone's working on a fix.
I have a brand new Blaze. I am unable to connect it to My Fitness pal or vice versa. Both apps want me to download or buy .  I have uninstalled my fitness pal and reinstalled it. i have told it not to track my steps and then tried to connect and nothing works.
I went into the www.myfitnesspla. com and was able to get my fitbit and myfitness pal apps to sync. not sure if this will work for everyone else.
