02-13-2023
20:56
15:44
LizzyFitbit
02-13-2023
20:56
15:44
LizzyFitbit
Following recent Fitbit IOS syncing problems - Fitbit will no longer sync with my Noom app.
I have deleted, unpaired, powered off reconnected, updated etc - repeatedly.
I contacted Noom customer support and received the following on Feb 10
“We've been informed that Fitbit is experiencing an outage that is interrupting services with some of their customers, which is also affecting the Fitbit connection to Noom.
Fitbit is looking into the issue and you can check the status on their Fitbit Server Status Page: https://www.fitbitstatus.com/
Once Fitbit has restored services, Noom will begin to work again.”
So - my question is - how long is it going to take for fitbit to correct?
Best AnswerI see this is is no longer posted as an issue, so I'll assume that it is fixed. Please respond if this is fixed
This would be a question to ask Fitbit, not fitbit users. However, if Fitbit knew the answer, the link would probably have been fixed by the time you posted the question
Fitbit has to identify the problem, and find a solution. In the past we had one issue where only people with an unrelated, misbehaving app installed was the issue.
So it normally may take a few days to issolate the cause
