When writing activities (exercises) to Health Connect, Fitbit does not write the calories burned as active calories burned records. Instead, it writes it into total calories burned, and in 15 minute chunks. This makes reading exercises recorded by Fitbit from Health Connect a bit troublesome.
Here's an example to further explain what I mean:
This is problematic for a few reasons, the main one being that the records are all on the :00, :15, :30 and :45 minute marks. This means that if you start a workout at 10:01, the calories burned between 10:00 to 10:15 would not be included in the data set from Health Connect. Similarly, if you end the workout at 10:59, we will not get the 10:45 to 11:00 record.
I believe that what Fitbit should record here is Active calories burned, starting at the activity's start time, and ending at the Run activity's end time.
