12-18-2018 19:53
12-18-2018 19:53
Yesterday and today, the Fitbit app is pulling in the wrong number of calories from MyFitnessPal. Did this stop syncing correctly for anyone else?
Best Answer12-20-2018 07:01
12-20-2018 07:01
Hello @Hsymons.
Thanks for getting back to me and letting me know.
If that is the case, maybe you could get in touch with MyFitnessPal directly. They should be able to take a look at what is going on and work on getting it to act as intended.
Let me know if you have any further questions.
Best Answer12-19-2018 06:25
12-19-2018 06:25
Welcome to the Forums @Hsymons.
Let me help you figure out what could be happening. I will be moving this thread to the Third-Party integration board as I think it is better suited for it.
The first thing I'd recommend is that you try to reconnect the two and then connect them again. You can find instructions on how to disconnect them by clicking here. That should help in fixing any issues there might be in the connection.
Best Answer12-19-2018 07:23
12-19-2018 07:23
Thank you for your reply, @LanuzaFitbit!
I tried to disconnect and reconnect them as you suggested, but the MyFitnessPal app will not allow it. Clicking the Disconnect button is simply acting as a back button and bringing me back to the list of connected apps, showing Fitbit Tracker still connected. Sounds like this issue is on MyFitnessPal's end then, not Fitbit's.
12-20-2018 07:01
Hello @Hsymons.
Best Answer12-20-2018 07:04
12-20-2018 07:04
Thank you for your help, @LanuzaFitbit!
12-21-2018 08:29
12-21-2018 08:29
Hello @Hsymons.
You are very welcome.
Hopefully this can be resolved quickly so that you can get back to working towards your goals.
If you have the time, maybe you could visit one of our Discussion boards. There might be some topics that pique your interest in there.
Feel free to reach out if there is anything I can help you with.
