06-06-2018 09:00 - last edited on 10-20-2018 12:09 by SelmaFitbit
Did a run about 2 hours ago and it's not syncing onto Strava. Won't let me upload manually which I read about on another forum. Anyone else having issues?
Moderator edit: label
06-12-2018 17:32
06-12-2018 17:32
My run tonight hasn't synced yet. Updated to newest ionic firmware last night. Yesterday's run synced fine prior to firmware update.
06-12-2018 18:05
06-12-2018 18:05
Same thing tonight. My runs are not auto uploading to Strava. I've revoked and re-added strava to my fitbit account, but no change. I was able to manually upload, but that's not the point.
06-12-2018 18:05
06-12-2018 18:05
I manually uploaded the tcx file into Strava without issue. Then I started a GPS walk around my house as a test and it synced fine. Not sure why the one was missed, but it appears to be working for me for now.
I did revoke and add back Strava access in between activities.
06-16-2018 12:55
06-16-2018 12:55
Hi there @Blaraway welcome aboard to the Fitbit Community and thanks for stopping by @Robby1870 and @EricInFL.
I was reading you were not able to sync with Strava. My apologies for the late response and I'm wondering how it goes? Is the issue still persisting?
The best troubleshoot to try here, in case the issue continue is to revoke access to the Strava and set it up again as @Robby1870 mentioned before.
See you all around and keep me posted if the issue continue.
06-18-2018 17:33
06-18-2018 17:33
Syncing with Strava seems to be working okay now for me. It definitely was not on the day this thread was started. Some my activities on the problem day sync'd the next morning but some did not.
06-20-2018 04:39
06-20-2018 04:39
Hi there @Robby1870, thanks for reporting back the issue was resolved for you. If some of your activities did not sync with Strava, you can also export your GPS exercise through a TCX file. Yu probably know this, but if you need some additional information, refer to this help article: How do I export Fitbit data?
Take care and I'll be seeing you until the next opportunity.
01-04-2019 11:18
01-04-2019 11:18
Hi. My Fitbit Versa isn’t syncing with Strava. I went on a run last night. It’s uploaded to the Fitbit app but not synced with Strava. I’ve tried the troubleshooting you suggest but still no luck. I only got the watch at Xmas and runs have synced since then- albeit it did take up to an hour. Please can you help?
01-20-2020 09:13
01-20-2020 09:13
I updated my iPhone software and it fixed everything. I.e. the actual iOS software, not the apps.
04-11-2020 11:32
04-11-2020 11:32
Have revoked & reconnected my Fitbit to Strava multiple times following this advice & still doesn’t sync even though its says they are paired apps. Incredibly frustrating.
