07-10-2015
12:42
11:48
AngelaMa
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
07-10-2015
12:42
11:48
AngelaMa
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I can't get Fitbit to sync my exercises with my fitness pal. Mfp is sending info to Fitbit but it seems like fit bit isn't sending info to mfp. Please help!!
07-11-2015 16:21
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
07-11-2015 16:21
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
@Akire614 It's nice to have you here! Fitbit will sync steps and calories burned to MyFitnessPal, it won't sync the whole activity that you've tracked with your Fitbit. You can check this information in the "check-in" section of MyFitnessPal.
Hope this helps.
04-22-2018 13:19
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
04-22-2018 13:19
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
wrote:I can't get Fitbit to sync my exercises with my fitness pal. Mfp is sending info to Fitbit but it seems like fit bit isn't sending info to mfp. Please help!!
I'm having the same issue. Calories/workout isn't being sent to MFP but it will send to Strava? I have the Ionic.
04-24-2018 17:52
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
04-24-2018 17:52
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
It's great to have you here @lukewheldon! I've noticed that sometimes the third-party website is the one that's having issues and not directly Fitbit, this might be the reason why it's sending information to Strava but not to Fitbit.
You can try unlink and relink both applications and see if the integration between Fitbit and MyFitnessPal starts working again.
Hope this helps!
04-25-2018 13:37
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
04-25-2018 13:37
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Hi,
My data from MFP is syncing to Fitbit; meals and water, however my steps are not syncing from FitBit over to MFP.
Thanks
04-26-2018 08:38
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
04-26-2018 08:38
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Who Voted for this post?
It's great to have you here @VonM! I would like you to make sure you've chose Fitbit as a tracker that will sync your steps to MyFitnessPal. To do so:
If you are on iOS press more / if you are on Android tap on the horizontal lines in the upper left corner > scroll down through the menu and select Steps > Here select Fitbit tracker.
If you are doing this from the web browser, in the same page where you connect your accounts, select the tile "Steps" ans select Fitbit tracker.
Hope this helps! Keep me posted.
