08-25-2015
06:52
08:12
AngelaMa
08-25-2015
06:52
08:12
AngelaMa
I just recieved my fitbit today! Im super excited but I did want to synch it with the Myfitnesspal app. I log in every day including all food, water and excersize.
I have synched the fitbit but its still not sending my steps and calories burned to the fitnesspal app.
I also want to know if its possible to sync my food, calories, and excersise from both portals so they read the same thing?
Best Answer08-25-2015 08:48
08-25-2015 08:48
That is definitely what should be happening. I would suggest giving it a little while to see if it just takes some time to sync the two. You could also try to disconnect the two from within Fitbit and reconnect. Are you getting any information sent between the two?
MakMak | Community Council
Best Answer08-25-2015 10:38
08-25-2015 10:38
MFP will show "Fitbit calorie adjustments" from Fitbit. MFP will sync "meal summaries" to Fitbit. It's mostly functional, but you won't get full integration or similar looking data on both sides.
