12-11-2016 04:27
12-11-2016 04:27
I have been using Myfitnesspal for a few weeks now as I find it easier to manually enter food and exercise (still waiting on my flex 2). But for the last two days Fitbit and Mfp seemed to have stopped communicating. Any suggestions anyone?
Helen | Western Australia
16:36
09:45
12-12-2016
16:36
09:45
Welcome to the Community @NellyG! You may want to check this MFP third-party app post information to see what data is going to sync between those. Since, you don't have your Fitbit Flex 2 yet.
Please unlink both applications to see if they start communicating again. To do so from Fitbit Dashboard:Go to your Dashboard > click on settings > Applications > there you'll see MFP below that click on "revoke access" . You should unlink Fitbit from MyFitnessPal as well to make sure the unlinked procedure was successfully completed and now you can link them again.
Additionally, you may want to check the Fitbit Flex 2 Product Manual to start learning the features from it.
Hope this helps. Let me know how it goes!
12-12-2016
16:36
09:45
12-12-2016
16:36
09:45
12-12-2016 18:41
12-12-2016 18:41
Ahhh thankyou!! That was what I was trying to do but following your instructions it worked. I am now back on track. Thanks again ![]()
12-13-2016
13:41
09:44
12-13-2016
13:41
09:44
Sure @NellyG! I'm glad to hear that it worked once you followed the instructions, I posted.
Hope I can continue seeing you around. You may want to check the Discussions Board and find new friends and healthy tips. ![]()
Best Answer03-08-2017 13:02
03-08-2017 13:02
I have tried the steps but can't tell if it has worked or not since I haven't worked out yet today. Is tgehre a way to tell quickly?? The two apps having been speaking to each other for a few months now. I just thought it was my fitbit but bought a new one and still not working.
10:33
09:43
03-10-2017
10:33
09:43
Hey there @DanaKY! You can try logging food and this should transfer from MyFitnessPal to Fitbit, this way you can confirm the apps are syncing again.
Let me know how it goes.
