03-25-2021
11:57
19:21
AndreaFitbit
03-25-2021
11:57
19:21
AndreaFitbit
I've tried disconnecting and reconnecting the apps, logging out of both, and resetting the phone. Still no syncing of steps from my FitBit to either MyFitnessPal.com or MyFitnessPal app. Any other ideas besides revoking access (i.e., turning it off and back on again)?
Moderator edit: format.
Best Answer03-25-2021 12:17
03-25-2021 12:17
Exercise not syncing yet again?
Best Answer03-25-2021 13:34
03-25-2021 13:34
I have the same issue, and I've tried everything too!
Clearing cookies, deleting the apps, unlinking and revoking, etc etc etc. Nothing is working. I don't know what else to try.
03-25-2021 13:41
03-25-2021 13:41
I have also tried revoking access in the app and on the browser version of each site. I'm at a loss here.
03-25-2021 13:52
03-25-2021 13:52
I'm having this issue as well. Is the problem on this end, or with MyFitnessPal?
Best Answer03-25-2021 14:53
03-25-2021 14:53
Same yesterday I disconnected and reconnected and eventually it worked today nothing it’s stuck at 4.5k steps when I’ve done 10k! I’ve tried everything recommended! Thinking to just get an Apple Watch!
03-25-2021 15:39
03-25-2021 15:39
Same here. Updated Inspire 2 firmware...broke the interwebs. Well, the MyFitnessPal sync, at least.
Best Answer03-25-2021 16:29
03-25-2021 16:29
This might be the culprit: https://support.myfitnesspal.com/hc/en-us/articles/360056777832-2021-Messaging-Regarding-the-Status-...
03-25-2021 23:25
03-25-2021 23:25
Glad to know they’re working on it! Mine synced overnight and looks to be working again
Best Answer03-26-2021 04:42
03-26-2021 11:21
03-26-2021 11:21
My steps are updating as of last night but I'm not getting any calorie adjustments in the app. I have premium and have opted into it. Any thoughts?
03-26-2021 11:27
03-26-2021 11:27
03-26-2021 11:32
03-26-2021 11:32
I have same issue today. No sync again
Best Answer03-26-2021 12:46
03-26-2021 12:46
So I've had this issue with my Ionic and a previous Samsung tracker. It seems to be a myfitnesspal issue. I did find a work around though after sleuthing! (This is for Android phones, if it works on Apple please confirm) I downloaded an app called Health Sync. It does cost 2-3 euros/dollars but it's for lifetime use. I was then able to use it to sync my fitbit to Google health, and then set my fitnesspal to link with Google health. Everything updates accordingly now.
I found this work around on the my fitbesspal forums, apparently this issue has been happening for quite some time.
Hope this helps!
Best Answer03-26-2021 12:51
03-26-2021 12:51
I meant Google Fit- not Google Health. It also has resolved intermittent tracking issues. No issue over the last year.
Best Answer03-27-2021 13:13 - edited 03-29-2021 23:36
From fitbit's side, the best we can do is to suggest revolking and reconnecting the two accounts.
If this fails to work, the next step is to reach out to MFP since their isn't anything else that can be done from fitbit's end.
Best Answer03-29-2021 15:22
03-29-2021 15:22
@Andria1 the issue is on MFP. Fitbit is not the ones losing connection. If you check you will see a lot of posts about MFP not syncing. Many have moved away from MFp for that reason. An apple watch won't solve the problem.
Best Answer03-29-2021 15:24
03-29-2021 15:24
@crimsonlibrus great find! This explains the recent issues.
Best Answer03-29-2021 23:37
03-29-2021 23:37
With a little search on MFP I find their response.
Best Answer03-30-2021 00:25
03-30-2021 00:25
