01-07-2017 04:22
01-07-2017 04:22
I can't get my fitbit to sync with my fitness pal - it just isn;t reading that i've done any steps on MFP although it seems to be connected.... Any advice?
Best Answer01-12-2017 12:27
01-12-2017 12:27
Thanks for being part of the Community @krsol! You may want to double check which data should sync from Fitbit to MyFitnessPal. (The steps and sleep data can be viewed in the "check-in" section of MFP).
If your information is still not syncing, please try to unlink and relink both applications.
Hope this helps!
