03-10-2015 07:22
03-10-2015 07:22
Hello!
I've done a little digging but couldn't find a thread that answered my question so apologies if this is a duplicate...
I have my Fitbit ChargeHR synced with MyFitnessPal to record my food intake and Endomondo to record any exercise (usually walking to/from work, exercise bike at the gym) however I'm not sure if my Fitbit daily steps are being taken into account in either app.
Is there a way to enable this (without it duplicating the steps during my walk to work) and if so, which app is best for this?
Cheers,
C x
Best Answer03-11-2015 07:04
03-11-2015 07:04
I hope you are having a great day @Caribo! To answer your question, if you are using your tracker to register your step count on a daily basis, this information will be shared with MFP and Endomondo, so you do not have to re-enter your exercise or progress on those applications. If you believe that your step count is not transferring properly, I suggest you unlink and relink both accounts to get this fixed.
Good luck! ![]()
03-11-2015 07:04
Good luck! ![]()
Best Answer03-13-2015 07:53
03-13-2015 07:53
Thanks @Mcore - I unlinked MFP and FitBit, relinked them then went back through my diary on MFP and was able to see the calories adjustment for my steps no longer shows 0
03-14-2015 07:38
