When i have a question like this i go to my friend Google and type in "endomondo Fotbit". I see that the first hit points to Fitbits interactive, searcjable, help documents. See https://help.fitbit.com/articles/en_US/Help_article/1290
Basocally you log into your account on endomondo, then ask them to connect to your Fitbit account.
That's is the first I did,
So which step doed it faol at.
Log into endomondo
Set up the connection
Endomondo sends you to a special page on firbit
If your not, you log into yhis pahe
Aprove the request to connect endomondo.
If it doesmt wprk, youll need to contact emdomondo, Fotbit vant help
The problem is that I can't connect charge 2 with my galaxy s7 by BT. It's linked but no connected and I try to find it but my phone don't see charge 2.
Whit the fitbit app, there is not problem. Sync perfectly.
Thanks
Sorry for my english
Best AnswerYou say your Fitbit app syncs fine, this is how it works.
Yes that ts right, the tracker can not be connected to your phone using the BT screen, and there is no reason to.
As for connecting your endomondo account to your Fitbit account, you need to do this through endomondis website, just as the instructions i point to above.
This connection is between the two accounts and has nothing to do with the Charge 2.
Please follow my link again, read the help and do step by step.
03-18-2017
10:39
07:24
03-18-2017
10:39
07:24
Hey, @Miguel1984! Thanks for being here. As our good friend, @Rich_Laue explained. Your Fitbit tracker connects via Bluetooth using the Fitbit App. So if your tracker is syncing correctly to you Fitbit App, then you should not have problems.
Here you can find all information regarding connectivity with Endomondo and Fitbit. Also, in this page you can see a list of compatible Apps to link with your Fitbit account and then please follow these instructions to pair your two accounts. (Fitbit-Endomondo)
Let us know if you have questions. 🙂
