10-09-2017 13:59
10-09-2017 13:59
So my fitbit won't connect to my weight watchers app all I get is user not found 404 message errors found. I have a huawei p10 lite, I've tried all that I can find disconnecting the app etc but still get the same!!!!!! Help I've spent nearly 2 hours trying to figure this out
10-14-2017 11:02
10-14-2017 11:02
Hello @Nella1986, welcome aboard to the Fitbit Community! I was reading you are getting an error when you try to connect this integration through the app. Have you tried to do this through the web site of weight watchers?
If you haven't try through the website, do the following steps:
If the issue persists, please contact the Weight Watchers customer services team at 1-800-651-6000 or http:
See you later and hope this helps.
03-04-2018 18:26 - edited 03-05-2018 17:39
I have the same problem. I contacted WW Help and they never did find a solution. Can you please look into this????
04-25-2018 10:13
04-25-2018 10:13
I found that when i selected to only sync activity from fit bit device would not display in WW app
i selected all and device showed
02-01-2020 09:08
02-01-2020 09:08
Thank you because this is the only thing that actually worked!
