Fitbit won't show my weight history
There is no way to sync my weight history from my fitness pal that I have been using for a few years and fitbit so I went on the my fitness pal website and manually wrote down all the dates and weights that I had entered over the past few years. For some reason fitbit is showing all the datapoints on a list and confirming that I've entered them correctly but its only showing  the more recent ones on the graphs and on my dashboard where it says total weight loss its only showing my recent weight loss and puts a recent weight as my starting weight, not where I started from a few years ago when I began losing weight.
1 REPLY 1
Hi there @jabell2008. It's great to see you in the Fitbit Community!
If you would like to see your total weight log, you can choose the "All" option for it to show everything from the first time you logged something either from an Aria scale or manually. For that, you need to go to the Log section, click on weight and select if you want to see the week, month, year or all. Also, at the bottom in the measurement history, you will be able to see previous logs by clickin on "Load 10 more". You can use the following image as a guide.
Hope you find this helpful and if you have any other concern, please let me know!
Ferdin | Community Moderator, Fitbit
