01-03-2017 19:15
01-03-2017 19:15
My Fitbit is syncing up to the Fitbit app and showing my steps and exercise for the day but it will not sync up to myfitnesspal app. I was doing this without a problem for several months and stopped around October. I'm trying to begin syncing the two apps together again and it continues to show 0 steps in myfitnesspal app no matter how many times I disconnect and reconnect the apps to each other
01-04-2017 06:09
01-04-2017 06:09
Hello @Cpime23, welcome to the Community, it's great to have you on board!
If your data is not getting trasferred from MyFitnessPal to Fitbit and viceversa, my suggestion would be resetting the connection between both apps. It's important to remember that the link must be removed from both ends to ensure they will link again next time.
Give it a try and keep me posted in case you need anything else!
01-04-2017 11:51
01-04-2017 11:51
01-04-2017 21:18
01-04-2017 21:18
I was able to disconnect my Fitbit from the Fitbit app and reconnect it. I also disconnected and reconnected my Fitbit from the myfitnesspal app... still not working
01-04-2017 21:29
01-04-2017 21:29
No advice here. I'm having the same issue. I've disconnected everything and reconnected. Synced it all. Even deleted the apps and redownloaded. Myfitnesspal stopped tracking steps as soon as I connected my Charge 2. Hope this gets fixed.
01-05-2017 03:45
01-05-2017 03:45
Hello @Cpime23, thanks for taking the time to reply. It's great to have you on board @HeatherJ0.
If after trying the troubleshooting from my previous post your apps are still not syncing correctly, my best recommendation would be contacting MyFitnessPal Support Team, I'm sure they will be more than happy to get you back on track.
Let me know the outcome!
01-05-2017 06:07
01-05-2017 06:07
01-05-2017 13:43
01-05-2017 13:43
Having the same problem here. I have re-set everything and both apps say they are connected but no Information is being transferred.
01-05-2017 18:45
01-05-2017 18:45
It sounds like MyFitnessPal has not upgraded things on their end for the new Fitbit devices. There is only so much Fitbit can do.
01-06-2017 20:27
01-06-2017 20:27
I am having the same problem. I'm not sure exactly when it stopped linking but I think it happened after one of the more recent updates. Same Charge HR I've had for a year and a half!
01-13-2017 07:36
01-13-2017 07:36
Same issue here, although I am using an Aria that I've had for a year. The sync worked beautifully right up until the morning of Nov 25, at which time I updated (reluctantly) the Fitbit iOS app to the "permanent" new dashboard (which I hate, btw, not that Fitbit cares)! This update is what seems to be the problem, nothing else. I have gone so far as to delete and reinstall both apps, reset my Aria multiple times, and almost, but not quite, threw the darn Aria (which drains its battery in a day and rarely will sync properly) against the wall! And let's not get started on the ongoing stalemate over integration with Apple's Health app!!!!!
01-14-2017 17:18
01-14-2017 17:18
Same here... I just got a new charge 2 and my fit bit app will not sync to weight watchers or my fitness pal. I've tried everything, even set up a new fit bit account
01-15-2017 05:01
01-15-2017 06:57
01-15-2017 06:57
Yes I tried all that... when it says to connect device on weight watchers app... the login for Fitbit should come up to log into Fitbit and it does not it just says it's connected, which it isn't. I finally got my fitness pal to work last night by disconnecting and waiting 15 minutes before reconnecting and it worked... so I am pretty sure it's an issue with weight watchers. I already contacted them and tried all the steps they suggested... but still no luck.
01-15-2017 06:58
01-15-2017 06:58
This isn't what I did to get MFP to work
01-15-2017 06:59
01-15-2017 06:59
I mean *this is* what I did to get MFP to work (above post) 😊
03-06-2017 05:52
03-06-2017 05:52
I'm having the same problem. I used it for a year and now neither one is syncing. I have removed both apps, redone loaded, etc- all to no avail. I even have a new phone and started over and it's still not working!!!
03-06-2017 08:59
03-06-2017 08:59
