05-30-2015 06:21
05-30-2015 06:21
Hello , not sure if this is a normal problem but, i just bought a surge watch and startet my Fitbit adventure , been using endomondo pro with my phone to track before this.
But now after i sync my accounts , if i run / hike / other on my surge, it sync to fitbit just fine, but will not post the workout on endomondo unless i export and import it myself. But at the end of everyday it does auto post my "steps" ect from Fitbit to Endomondo , so something works. Anyone that could help me with this ? 🙂 Thanks
Best Answer06-02-2015 11:24
06-02-2015 11:24
Welcome to the Fitbit Community @sesam! When you're cycling Fitbit Surge will steps because you're wearing it while you're biking. Since you're using Endomondo I would recommend not using your Fitbit while you're biking instead just use Endomondo because Endomondo is syncing the activity but it's not deleting the steps that you're getting from your tracker.
Hope this helps!![]()
Best Answer06-03-2015 07:28
06-03-2015 07:28
Hello @MarreFitbit , and thanks for the welcome. I have already goten some help from the Fitbit help line.
And the problem was not that the "steps" overlap`s , it was the fact that Fitbit workouts from surgewatch "gps" does not auto upload to Endomondo , you have to do it manually. But i hope they will change this soon :=) Thanks again
Best Answer06-03-2015 11:57 - edited 06-03-2015 11:58
Thanks for the details @sesam!
We hope we can implement this in the near future.
