12-27-2014 09:07
12-27-2014 09:07
i am having issues connecting the steps to display on my fitness pal app on my mobile devie from the fit bit and wasnt sure if i am missing something and open for suggestions? i had un-installed the pacer app, off the phone, which i used before the fit bit, and for some reason it is stil there in my fitness pal app, i went to add the device of the fit bit, in the step section, which when kicked over, says i am conncected with the fit bit..as i play around on the my fitness pal app, i notice everything else is coming over. thanks for any info
Best Answer12-29-2014 17:05
12-29-2014 17:05
@coreyj007 Hey there! You can see the steps and sleep data in the "Check-in" section of MFP. Please check that section and let me know if the steps are transferring to MFP.
Best Answer12-30-2014 05:29
12-30-2014 05:29
