@Samirella Welcome to the Fitbit Community! You should only use on of the two apps to track the food. If you use both Fitbit and MFP pal, foods will double. I recommend using MFP and once you sync; the food data will be transferred to Fitbit without having to log it on the Fitbit app as well. If not, try to revoke the access from MFP and re link them once again.
Try that out and let me know if it works! ![]()
Best AnswerI've been having the same issue for weeks. The Fitbit people just keep saying to unlink and relink the two accounts, which I've done several times but to no avail. This is an ongoing issue that's happening for lots of people but I've yet to see any kind of acknowledgment of the bug by Fitbit. (Surprise, surprise? Not really.)
Best AnswerI'm having the same issue. I received the Blaze as a gift and started using it Monday. I've been using MFP for a couple of years. I haven't logged any food via fitbit but it's randomly adding meals to my log that is not there. This is very aggravating.
