01-10-2017 04:05
01-10-2017 04:05
I plan my meals for the entire week, so in addition to doing all my prep on Sunday I also log everything into MFP dashboard for the week & make adjustments on the fly as needed. I recently got the Charge2 (had a Jawbone Up before) and I notice that it doesn't bring over my food log from MFP. If I go into MFP app delete everything & then re-add it will then register on the FB app. I am so in the habit of preloading everything I really don't want to have to change and add things in daily. Has anyone else experienced this issue?? Thanks in advance!!!
14:59
08:36
01-12-2017
14:59
08:36
Welcome to the Community @KellyG0428! Thanks for those details. Fitbit and MyFitnessPal should sync automatically. I would like you to make sure that you followed this procedure and you took into consideration this details.
If after checking the instructions provided below, your data is still not working. Please contact MyFitnessPa so they can further investigate.
Hope this helps.
