08-25-2014 07:52
08-25-2014 07:52
Hi,
I sync my fitbit and myfitnesspal apps together and several times now calories will sync incorrectly. For example, yesterday it says I ate 289 calories more than I actually did. I looked at the food summary in fitbit and it is counting dinner twice in the log but when I go to myfitnesspal it shows the correct amount. I have tried refreshing both apps, have restart both apps, have even disconnected and reconnected the apps and it is still showing up incorrectly. This has happened before but before it always corrects itself later. Why is it not correcting itself this time?
Best Answer08-25-2014 11:28
08-25-2014 11:28
Did you edit anything in fitbit? That's the only time I've had an issue (generally an issue with exercise). If not, you can try deleting one of the entries in fitbit and just keep an eye on it.
MakMak | Community Council
